NI Home
Cart Cart | Help
You are here:
Reply
Member
Rick K
Re: What IP should we get on IPNet?
In 8.6 you can generate the IP from the Xilinx tools and then use the CLIP Node to import the IP into LabVIEW FPGA. It is more involved than the new IP Integration Node experience, but it is still a very flexible way of integrating external IP. Here is a doc that goes through CLIP Importation: http://zone.ni.com/devzone/cda/tut/p/id/7444
Also, if you are still current on your software service (SSP) you can also upgrade to the latest LabVIEW version at no cost. If you purchased 8.6 (or 8.6.1)
Rick Kuhlman | LabVIEW FPGA Product Manager | National Instruments | ni.com/fpga
Check out the new FPGA IPNet for browsing, downloading, and learning about LabVIEW FPGA IP Cores you would be eligible for free upgrade.
Member
Poormanphysics
Hello Rick K:
Are there any IP that shows or points to a direction where a "digital, parallel I/O or high speed LVDS output from camera imager sensor" can be "deserialized/serialized" to produce a frame or image file? Our application is in the automotive camera hardware were usually proprietary and often times custom design hardware is used. It is neither of the usual camera standards (GigE, Firewire etc.) used but instead based on low level imager sensor protocols. In a sense what I needed is a "reconfigurable framegrabber" which can be flexible enough to accomodate image sensors from ST Micron, Aptina, Omnivision etc.
In my mind a FlexRIO with an adapter board (for the physical layer realization of the signals) controlled on a real time embedded controller on a PXI should be able to cut it - for the speed at least. However, to actually be able to write code to "serialize and/or deserialize" Horizontal and Vertical clocking, Image Frames, Synch is really to me an IP thing.
Thanks for any information that will lead me to the solution of this design problem.
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
Member
Rick K
[ Edited ]
at
Member
Poormanphysics
Hi Rick K:
I simply saw a "at" reply?
Berns B.
Member
.avi file
Is there a known working implementation of I2C slave implementation with LabVIEW FPGA?
Avi
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
