NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Noel
System Dir Access: Right set of directories?
[ Edited ]
Note (August 2008):  Thanks to all of the users who have provided feedback on these proposals.  At this time, NI is likely to proceed with the proposed LabVIEW API to access system directories.  However, NI has suspended plans to implement the proposed changes to the LabVIEW directory structure.  The proposed LabVIEW directory changes originated internally based on anticipated demand for NI to adhere to Microsoft Vista's directory recommendations. Since imposing a new directory structure impacts Alliance members and many of our other customers, we have decided to suspend these changes until there is a greater customer demand.
Question:
The above proposal defined a set of Directory Types to represent special operating system directories.   Do you agree that we have the right set of directories in the Directory Type list?  If not, what should be added or removed?
Message Edited by Support on 08-21-2008 01:42 PM
Knight of NI
Knight of NI
tst
Re: System Dir Access: Right set of directories?
I don't have any other directories in mind, but I wonder whether this should a ring (as it is in the example) or a typedef enum for forward compatibility (if the OSs add more directories).
Since it's unlikely people will upgrade to a new LabVIEW version and then decide to change the used directory in existing code, an enum is probably not required (the user can just delete the current ring and recreate it to get the new values), but I just wanted to raise the point.
___________________
Try to take over the world!
Member
wireman
I would like to see a way to lookup directories that are specified by the Build Specification. For instance, the build spec has a default support directory named <app name>/data. I like to place my config files in this directory, but there is nothing that I know of in LabVIEW that will give me the path to this directory (at least not directly).
If the build spec or install spec specify multiple support directories, it might be nice to be able to determine what those are when my LabVIEW application runs. If this is too labor intensive, then at least provide the single <app name>/data directory.
The key is to be able to change a directory in the build or installer properties and have the resulting application automatically know where to look for support files.
Knight of NI
Knight of NI
tst
Since the directories are relative to your app, why not do this yourself? OpenG, for example, has some VIs in its file package that can help with this, but it's fairly easy to write yourself.
Of course, you should note that if those config files are modifiable by the program, it's a problem having them under the executable's location because Vista doesn't like this. That's part of the point of the suggestions made by NI.
___________________
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
