05-31-2017 06:05 AM
HELLO,
I created a code in labview comms that sending a text,my question is how using USRP-RIO for transmitting the text and receiving it,in another word how to compile this code ?
thanks a lot,
06-01-2017 06:09 PM
I'm not entirely sure what you mean here. Are you using LabVIEW Comms to transmit and receive data on your device? What type of data are you transmitting? Where are you running into issues with the code you have created so far? What device in particular are you using? Have you tried running example code? If so, how did it fail?
Please provide as much information as possible so I can further assist you!
06-09-2017 05:59 AM
06-09-2017 05:44 PM
Do you have the NI USRP RIO driver installed? I ask because the driver provides a Simple Streaming sample project that is a great starting point for using a USRP-RIO. There are several host VIs that include Rx, Tx, and one that does both. These should get you up and running, and if you want to edit the FPGA code, you should be able to as well. Additional information about this project can be found here: http://www.ni.com/white-paper/52119/en.
Let me know if that helps!
Sunayna
