LabVIEW Communications System Design Suite
Error -1074100545 occurred at niusrprio_read.gvi.5240001
I try to run the sample "Projects" for LV comm 2.0
Other example/projects/learns working fine, but, got problem with this two projects
1) USRP RIO 120-160MHz BW Single--Device Streaming
2) USRP RIO 40MHz BW Single-Device Streaming
btw, i'm using USRP RIO (2943R) with 120 MHz BW)
couldn't find the error on the internet, or maybe i miss it
The error is:
Error -1074100545 occured at niusrprio_read.gvi:5240001
Possible reason(s):
Invalid parameter. The offset to start reading from or writing to is out-of-range or too high for the subsystem.
(3,206 Views)
I am having the same issue with an LTE application framework. By looking at the date you posted this, I imagine there will be no response from NI...
(2,821 Views)
