LabVIEW Channel Wires
LabVIEW could not create the requested channel endpoint File permission error; NI-488: DMA hardware error detected
Nevertheless, a networked Data folder would need much the same permissions to allow you and Windows applications to use it the same as it might a local Data folder.
Why is LabVIEW unable to use the LabVIEW Data folder when it's networked?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 11 of 13
(2,005 Views)
I'm glad you got things untangled.
I'm not sure if I can improve this much ... trying to explain in an error dialog all the things that could be wrong with writing to a path is pretty extensive.
I can at least look into getting the path into the error message.
Message 12 of 13
(2,005 Views)
Yeah, this was my first question: what path is it that LabVIEW has problems writing to?
From there, it's either permission problem or this whatever happened to me.
Thanks!
Message 13 of 13
(2,005 Views)
