LabVIEW APIs Documents
PCAN Driver
HI All
This driver is developed for phytec USB PCAN device.
Kindly Check the same.
Regards
Prabhakant Patil
Regards
Prabhakant Patil
Comments
dk91
Member
Member
on
Forgot to check the date.
RubCP
Member
Member
on
Hi Prabhakant,
The PCAN_USB.dll you have attached in the PCAN_Driver.zip is only for 32-bit systems? LabVIEW shows an error when calling the PCAN_USB.dll saying "Library not found or failed to load". I guess it has something to do with 32-bit / 64-bit because I copied the dll in both Windows/WOW64 and Windows/System32 folders and it seems it should be a different dll for each (but I am not sure about this).
Anybody had the same problem? Any idea to solve this issue?
Thanks for the Support,
Ruben
xaheer
Member
Member
on
Hi RubCP,
You can check API files on website of your hardware they will have both dll files for 32bits and also 64bits.
agilentvee
Member
Member
on
could you share PCAN-LIN Driver?
Contributors
