LabVIEW APIs Documents
Open Python Interface
Due to unforseen issues the OPI will not be available, until further notice.
Until it comes back I recommend watching this YT video on Python and LV communication, which might help in your case https://www.youtube.com/watch?v=1SBZIAjQeGI
Best regards, Piotr
Certified TestStand Architect
Certified LabVIEW Architect
Comments
Active Participant PrimaryKey
Active Participant
Feel free to comment, suggest improvements and report issues. Thanks!
Best regards, Piotr
Member Yogesh.Sinare
Member
Hello PrimaryKey,
Would we require python compiler installed on the system to use this toolkit?
Active Participant
Hejka Yogesh, that is correct. The toolkit requires you to have the python compiler. It works best if its registered with the system symbols. If its not you need to point to it when obtaining the reference with the API.
Best regards, Piotr
Member nikodem
Member
Are you planning to release it for older versions of LabVIEW (lke e.g. 2014)? Is there any stopping factor why it can't be done?
Member Mike_King
Member
Looks like a great toolkit, thanks for building it.  I hope to need it sometime for some python integration, could have used it in the past.
Active Participant
The only reason is not released for previous versions of LV is that I didnt test it yet on previous versions. It should however work, once saved for previous. I will save it for previous versions soon.
Best regards, Piotr
Active Participant
Hejka All, I compiled and tested the tool for LV2012 and later. Should be even easier to use in most current LV versions.
Best regards, Piotr
Member nikodem
Member
Dzięki/Thanks.
I'll try to test is as soon as possible, as this was a kind of tool that I was searching for a long time (I am aware that there was something similar available, but it was not freeware).
Member promisekeeper
Member
Active Participant
You should configure your interpreter Smiley Very Happy There is a button to do it there. Google it
Best regards, Piotr
Member
Thanks .. but theres another problem..Please help me to fix this.Thanks1.png
Member
also the TCP multiple connection vi dont run due to the problems stated on the printscreen below ..what should I do?thanks for the reply2.png3.png
Member
Active Participant
Right click on the places where the enum is used in code and select "Disconnect from type definition". The connection from python should be attempted when an actual server is up. The error in not handled in code.
Best regards, Piotr
Member
i cant find where to select Disconnect from type definition..Sorry im a beginner in python programming?..and for the labview problem about .ctl, what should i do?thanks for the reply.a.png
Active Participant
This comment section is not a good place for debugging like this. Please ask your questions on a normal forum and keep this comment section for comments only.
LabVIEW forum: http://forums.ni.com/t5/LabVIEW/bd-p/170
Python Forum: http://stackoverflow.com/documentation/python/topics
Best regards, Piotr
Member
Member
okay sir im sorry ..can you help me?
Active Participant
Hejka Promisekeeper, i have posted a reply on the forum with LV code that you should try, please let me know there if it helps.
Best regards, Piotr
Member TUDarmstadtLLX
Member
is there a way to run python function in LabVIEW?
Best regard
Contributors
