I'm trying to interface a shutter control unit using a RS232C .I'm getting a read time out error.I'm using LABVIEW,->serial.vi.I tried giving the termination character to my command.But its still not working .The command format is as follows :
[A][BBB][C...C][CR]
[A]: Command identifier (one lower case alphabet ,ASCII code,one byte)
[BBB]: command name (three upper case aplhabet characters ,ASCII code,three bytes)
[C..C]: Parameter(ASCII code)
[CR]:carraige return(0x0D)
i run the follwing commands in LABVIEW<->serial.vi:
rTSW
rTSR
and i'm getting the time out expired error.i'm even tried gving "\n" rTSW\n etc..but still i get the same error.
Any help in this reagard is appreciated.
