visa is not working with application builder
I made an application with old serial communication Vi and then an application builder. today it has some problems during acquisition in CSV file. Some points are "crazy points".Today I want to use VISA but to have a better control, the communication seems to be OK but when I make an application with application builder, it doesn't communicate anymore.
I'm not sure that VISA wll solve the acquisition problem.
(2,881 Views)
Did you install NI-VISA with the executable?
Ben
(2,881 Views)
If you are building the exe on the your development machine and porting it to a target machine, then the first test is if the exe runs on the development machine. If it does, that means the exe was built correctly. If it runs on the development machine but not the target machine, then that means you have missing or non-matching drivers or support files on the target machine.
(2,881 Views)
