visa importStyle and exportStyle bug
hi all,
i have a problem: method exportStyle from execution program of visaControl don't work (the result file is not correct) , it's ok using "method" from ide -> add control -> call activex export
your opinion? (Solutions? 🙂 )
Regards
Gianmarco Castagna
(3,006 Views)
Gianmarco,
Do you have more specifics on that error? I would like to replicate the problem here so that I can report it and get it fix for the next release.
I was not able to find any problems reported previously with this functions.
Keep me posted!
Juan Carlos
N.I.
(3,006 Views)
My "enviroment"
win xp home edition
visa driver 2.5.2
measurement studio 2.1
framework 1.1.
Error: "Error loading control A newer version needed.The default settings for the control will be used"
Code: view attach file (just a sample modified to showing the error ,is not my project 🙂 )
In my "environment" visa result not serializable,this is correct?
Regards
Gianmarco
(3,006 Views)
