03-02-2015 04:31 AM
Hello.
I am trying to communicate with a mesytec mscf-16 module through usb ( usb to serial converter chip from fdti ) . Using hyper terminal i can connect and send commands to the module but from labview i can't use the commands . it is like the module sens back the same string i write.
Is there any incompatibility between the fdti vcp driver and visa?
Solved! Go to Solution.
03-02-2015 07:55 AM
03-03-2015 03:19 AM
It works . Thank you.
