07-24-2009 08:50 AM
I have to connect an USB instrument to the PC in order to acquire data in LV.
My problem is that the instrument is seen from the pc as a HID keyboard, and I already have a bar code reader (another keyboard).
Is there any possibility of using a virtual serial port to acquire the data??
07-25-2009 03:02 AM
07-29-2009 03:22 AM
Consider I'm using a normal keyboard. My idea was to find out a sw able to create a virtual COM port, and let the computer see the data input by the keyboard as they are input from the serial port.
Is it possible?
I found out a post written some years ago in the topic "using multiple HID (Keyboard)":
"...One Month Later... Thanks for the advice guys. For the barcode scanner, I reconfigured it to emulate a serial port and used VISA to send trigger commands to the device. (I didn't notice this capability before.) Thanks again!
-Adam "
that's exaxtly what I need! But no further information on that topic 😞
Any idea??
thanks in advance
07-29-2009 09:14 AM
As Albert said, it depends on the driver that the vendor provides. Unless you want to use VISA and write your own USB driver, you really need to be asking the vendor whether they have an alternate driver.
I'm a little confused about the keyboard emulation, though. Does this instrument constantly stream data? If it's truly a keyboard and not some other HID device, you would be getting data if you simply opened a program like notepad.
07-29-2009 06:18 PM
-Adam "
I have seen some barcode scanners that come with a sheet of barcodes you can scan to reprogram the scanner. One of these barcodes probably instructs the scanner to identify itself as a keyboard, and another to identify itself as a serial device. This is all very vendor-specific.
-Jason
08-26-2010 04:41 AM
hey i am trying to emulate mouse and keyboard both.i have done it successfully on a windows xp machine but there is some problem for windows 7.
has anyone tried ???? the difference between both is i think only the SDP service request.
in XP,it is SDP service search request
but in windows 7 it is service search attribute request.
i checked my data with the real mouse. everything i am sending is same as that of the real mouse.
the thing is that after there is disconnection from the SDP channel,the host is not sending any connection request with psm = hidcontrol channel.
and it automatically disconnects....
please help me.....
09-29-2011 12:31 AM
Here it is
http://shtrih-center.ru/TKP_3274.pdf
Download Link
http://www.zbaus.com/downloads.php?id=77
Hope this Helps.
