1. I have tried method 1 in that KB you have adviced me. I uninstalled Ni-Visa and instaled HP-Visa (is not clear from the KB description, if HP should be primary or secondary, side-by side. I tried both configurations). Of course MAX does not find gpib board in any case. To solve this problem in the KB is written "you must right-click on the control or constant and select "Allow Undefined Names." In this step I stopped, because in the MAX I did not find where this "constant or control" is. I tried to do right-click on "devices and interfaces", but only "Create new..." menu appears. The right-click on anything in the MAX does not open the menu which contains "Allow undefined names". Can you please, specify where this right-click should be done to allow undefined names and to continue with method1 to reach the goal of using LV for data aquisition.
2. Then I tried method 2 from the KB. I have uninstalled HP-visa; HP-SICL and Ni-Visa3.0 is installed, NiVisaTulip.dll passport is allowed and F5 refresh made. In MAX in the section Devices and Interfaces I can see "? Miscellaneous VISA resources" with "GPIB1::22::Instr" (it is for one device with address 22). Instead of "? Miscellaneous VISA resources" I expected, there will be written something like GPIB1(USB-GPIB). In this point I have few questions.
a) Is it correct if there is only "? Miscellaneous visa resources"?
b) If I configure usb/gpib card with Agilent config. utility to SICL name gpibn and visa name gpibn, where n is some integer, MAX shows everytime gpib1. There is only one gpib card installed in the PC, so I expect there will be gpib0 in the MAX.
Now, when I run nivisaic, I can see gpib interface named gpibn with gpibn::22::instr. I can communicate through this interface to the instrument in the session opened by double-click on the resource. In the Nivisaic there is also another interface marked as unknown-gpibn::intfc and gpibn::servant. I cannot communicate with this interface. When I install HP SICL with HP visa as secondary, side-by-side, this "unknown gpib" disappears. Then nivisaic seems to be OK(but MAX still shows "? miscellaneous visa resources"),the status of each operation in NI Spy is succesfull. I think I did everything required in method 2 of KB but, I cannot perform any data aquisition by LabView. Are there further thinks to do for starting data aquisiton? Thanks for any advices.
