The driver does support the following models:
1002,1012,2002,2012,2014,2022,and 2024.
On initializing the driver, the default setup taken is for the model 1002 which has 2 channels.
To initialize the driver for the 2024 model, you need to specify the model number in the OptionString parameter of the InitWithOptions functions.
Example: "Simulate=0,RangeCheck=1,QueryInstrStatus=1,Cache=1,DriverSetup=Model:2024"
This is also detailed in the function panel help for the OptionString.
Hope this solves your problem.
Ravi
