three applications where BJT were used in the reversed active region
hello i wanted to know the applications where the BJT was used in the reverse active region?
an example of an application is the TTL technology. IS there any application where this BJT was used in the reverse active region?
thank you very much :robotwink:
Message 1 of 8
(4,092 Views)
What does this question have to do with instrument control or NI hardware?
Message 2 of 8
(4,089 Views)
where should i post this question?
Message 3 of 8
(4,084 Views)
I'm not sure it applies to any NI hardware or software except perhaps Circuit Design. How did you even find this site? I don't do much circuit design so I don't have a clue except to try Google.
Message 4 of 8
(4,081 Views)
my friend used to post his questions related to labview and he told me that I can get some assistance.
thank you for your time
Message 5 of 8
(4,078 Views)
Yes, but only if the question is not offtopic. I.e. related to LabVIEW (in the LabVIEW forum) or instrument control (here).
We typically don't answer technical questions about molecular gastronomy, fashion, religion, politics, or any other question not directly related to NI products. Of course if you are a real nutcase, you might get some replies anyway, but that's an exception :D)
We have a the breakpoint forum for non-technical, more social, offtopic discussion, but I don't think your question would fit there.
As Dennis already said, you best bet is to find a suitable community specializing in the specifics of your problem. Also try to learn how to efficiently post a question: Provide some background why the answer is important to you and what you are trying to do (we don't do homework questions or help you pass an online quiz). Avoid acronyms, spell them out the first time they are used.
Message 6 of 8
(4,060 Views)
alt.sci.electronics.design
or more general
alt.sci.electronics
But who still know nntp??
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 8
(3,953 Views)
I've seen it used in low rep rate flashers.
Message 8 of 8
(2,914 Views)
