Dear Mr. Logan,
thank you for your reply sir,
well there is a small change.. i am now working with the TDS784A ( it is no longer in production )..
i am not very much interested in continuous acquisition..
i am attaching 2 files sir,
the first one is the vi tht i built for use with the TDS5104B ( this functions as per my requirement )..
the second one contains drivers as obtained from NI for the 784A....i am unable to find the initialize and close functions in these .... could u help me modify my VI so that it runs for the 784A?
to answer your other question sir, i was indeed using instrument drivers obtained from tektronix.com , specifically for labview applications..
i hope you will be able to help me modify my VI to function for the 784A,
thank you,
Sairaj.
