1.whenever i use ibwait with mask bits ATN ,DCAS etc through interactive control, EARG(invalid argument) error is showing up.why?
2.what are the compatibility issues bet IEEE 488(.1),IEEE 488.2 and HPIB.Could i use IEEE488.2 calls like DevClear,findListeners ,remoteEnable etc over a NI PCI-GPIB bus having instruments with different versions of IEEE488?.
3.what is the difference between between DevClear call and
any device specific calls like preset or clear?
4.Using GPIB-ENET requires any change in the application software which has been developed using general GPIB 488 and 488.2 commands ;not VISA calls?
5.what exactly will be the form of Read data(ASCII bytes)?
Does every call will be having unique format with different delimiters between tokens?Do i need to know the the output format of every read command i make?
Jay
jeyaseelan P
AutoTEC Systems Pvt Ltd,
Bangalore-46
