05-26-2016 06:01 AM
Install information:
OS vsersion : openSUSE 13.1
NIVISA : nivisa-15.5.0
NI4822 : NI4882-15.1.1
When I run the command "NIvisaic",the error occurs as following :
Can't load library /usr/local/lib/liblvrt.so.14.0
libXinerama.so.1: cannot open shared object file: No such file or directory
To download the LabVIEW Runtime engine, go to
http://www.ni.com/rteFinder?dest=lvrte&version=14.0&platform=Linux&lang=en
05-26-2016 12:16 PM - edited 05-26-2016 12:16 PM
@melanie1129 wrote:Install information:
That error message is pretty clear isn't it? Download and install the LabVIEW Runtime engine.
05-26-2016 09:47 PM
05-31-2016 09:36 AM
The error might be a little misleading. This is actually the dependency you will need to resolve. You should be able to find libXinerama in the OpenSUSE package manager. Be sure to install the 32-bit version.
06-01-2016 05:43 AM
