08-28-2014 06:35 AM
I change the name of my visa resources in NI max and I want to actually save these names as group name in a tdms file
I could find intf inst name
thank you very much for your help
regards
Pascal
08-29-2014 07:06 AM - edited 08-29-2014 07:08 AM
Hello PBAN,
You could use the NI System Confifuration API to accomplish this:
https://decibel.ni.com/content/docs/DOC-13216
By using this API you can easily create examples like the one in attachment.
But there is alot more to this API, then just this example (or renaming aliases).
The NI Example Finder should provide you with enough examples.
The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at:
http://ni.com/samplecodelicense
Alternatively you could also read out the Aliases ini-file from your hard drive and programmatically change this:
http://digital.ni.com/public.nsf/allkb/F02B2BF8943A31D786257393005D16F1
If you plan on using the second approach, then please use the configuration file VIs that allow you to read/write .ini files and that are by default abailable in LabVIEW.
09-01-2014 02:13 AM
Thank you very much Therry
I will test the different approaches to see what works best for the several program's that I have to write
Just one small question I forgot to tell that i'm using labview 2012
and I was on able to open the findalias.vi that you attached
would it be possible to post it to 2012 version
thank you again for your help
Pascal
09-01-2014 02:19 AM
Hello Pascal,
Here is the 2012 version of the VI.
09-01-2014 04:32 PM
Now with attachment.
Do note that the sample code license mentioned above is still valid.
08-08-2019 11:01 PM
Hi ThiCop
Can I know where is it been used? Can I use this .ini file to auto configure my VISAconfig.vi when I create executable ?? If yes, how can I do this??
Also When building Executable I am using some .txt and other files that I am including while creating .exe but how will the application access these included files at the exact time where I am needing these in my main application
Thanks and Regards
Baig
