01-12-2012 12:31 AM
please see the attached file
I think it dont need to convert string to decimal.
01-12-2012 01:24 AM
You are probably right, the Acquire Waveform VI will probably have extracted the correct data.
I take it there is a continuous waveform visible on the scope screen when you run this VI?
01-12-2012 02:13 AM
Dear Ray Farmer
Thank you again.
Yes, in my oscilloscope screen I can see continuous waveform.
Also, when I use a probe in labview, probe show data correctly in Y-Axsis. (X-Axsis (time) is always=0 but Y-Axsis is changing)
for example
x=0 y=-1.4
after nest sample again
x=0 y=-0.8
again
x=0 y=-.6
etc
01-12-2012 02:33 AM
well your time valve should be changing, all your point are at zero, hence the reason why you can not see a waveform.
I can not see what's in the Acquire Waveform.vi at the moment because I dont have that driver so I dont know why you dont have a time parameters.
01-15-2012 12:52 AM
Dear Ray Farmer
Thank you again
I use Labview 8.2 and NI VISA 5. I download Tektronix TDS 200 1000 2000 Series Oscilloscope driver from
In this page I read, Application Development Environment (LabVIEW 8.2.1 Upgrade) and NI-VISA 3.2.
Do you think I must to use Labview 8.2.1 and NI VISA 3.2?
Best regards
01-15-2012 01:54 AM
01-15-2012 02:35 AM
Dear Albert Geven
Thank you for helping
However, I have another problem.
I use Tektronix TDS 1002b and I want to read data from oscilloscope but any data could not be show in graph in my VI.
Time is constant in my VI and not changing.
Regards
01-15-2012 05:07 AM
Dear Ray Farmer
Please see attachement.
I use waveform output.
Y output has a scaller not vector when I run program. But for waveform gragh Y must be vector.
Best regards
01-16-2012 05:20 AM - edited 01-16-2012 05:22 AM
that means you have only acquired one point.
Is it possible to capture the display off the scope with a digital camera showing the waveform you are trying to capture and post it here?
Can you capture the data using NI Spy and post the recorded data file here?
01-16-2012 06:30 AM
Please find the attached file.
A video from Sin wavefrom on osiloscope and capture data using NI I/O trace.
Regards
