Which version of the GPIB drivers are you using? We recommend using NI-488.2 v2.0 for your GPIB-ENET device (for Windows XP and Windows 98).
1. Should it be possible to get LabView 5.0 with 98SE talking to the older GPIB-ENET box, at least to set the IP address? Is this failing because I need to download the license (p/n 778258-02)?A: If you have version 2.0 of the drivers, you should be able to assign the IP okay. Do you see a pattern in the LEDs flashing? Check the READY LED and see if you see a pattern, as this indicates an error code. The following formula can be used to find the error code:
error code= (long flashes-1)(short flashes-1)example: 3 long flashes, and 9 short flashes = (3-1)(9-1) = 28If the READY LED does not stop flashing, it indicates that the GPIB-ENET does not have a valid IP address assigned to it. According to this
KB:
The problem is the Ethernet address. The field for the Ethernet address in the IPAssign Utility is meant for the last four digits of the Ethernet address on your GPIB-ENET (the first part of the address is the same for all GPIB-ENETs, so it is pre-filled for you). If you run the IPAssign Utility again and fill in the last four digits of your GPIB-ENET's Ethernet address (in the format: xx:xx), then you should be able to assign it an IP address successfully.
More details: The Receive LED flashes because the Ethernet header for the packet is correct and the GPIB-ENET recognizes that; However, the header was actually duplicated when you entered the Ethernet address in the IPAssign Utility, so it did not match the exact Ethernet address of that particular GPIB-ENET. The only numbers that need to be entered into the Ethernet address field in the IPAssign Utility are the last 4 numbers in the format: xx:xx.
Note: The user must decide what the IP address is going to be. Your IT department could probably help.The Ethernet Address however, is statically programmed into each ENET. It's usually labeled at the bottom of the unit.
Also, refer to
this KB regarding some IP issues we've had with some of the older GPIB-ENET devices.
2. If I order LabView 7 and install it on Win XP, will I still need to download the license to run it, or is that included in version 7?A: You should uninstall and reinstall NI-488.2 v2.0. If you already have this driver, you will not need to re-license it. The driver is not included with LabVIEW 7.0 by default.
3. Once I get LabView 7 and the driver and the license (if necessary) will I be able to assign the IP address with this setup?A: You should be able to assign the IP fine. Look at the response for first question above to make sure you are assigning the IP correctly.
Anu Saha
Academic Product Marketing Engineer
