Click the OK button on the dialog box and the next frame will execute. Each frame has a dialog box. You will have to click ok on each one. You should see the dialog box appear 4 times. The messages refer to the frame number that they are in. This is only to prove to you that each frame is being executed. I set the subVIs to show front panel when called, close afterwards if originally called, and suspend when called. I only did this so I can run it on my pc without any hardware. You should turn it off. This is a pretty basic debug tool. Right click on each WriteBS subVI and select SubVI Node Setup. You will see three checkboxes. Uncheck them all. The options help you debug subVIs. You should be using it a lot or the breakpoint. When the options are set, the subVI will pop up and to run it, click it's run arrow. To continue, click the up arrow next to it. It's sort of like single stepping through your program. Here's the same example with all of the debug stuff turned off.
