05-13-2005 01:18 PM
@Dennis Knutson wrote:
Nothing happens at all? When I try it, it seems to work as designed. Of course I don't have the instrument connected but when I change a front panel control and run the VI, I get the serial write sending out commands.
The VI you've posted is designed to run as a subVI.
05-13-2005 02:58 PM
05-13-2005 03:23 PM
To find a control on a block diagram, you can double click the control with the postion/size/select tool (arrow pointer or right click the control and select find indicator. The load and time control is actually is single Boolean control.
p.s. I'm glad I don't have to edit or maintain the VI you posted. Way too hard to read. It violates just about every style guide I've ever seen. Wires everywhere and they don't go in any logical order, the right directions, hidden by other objects, etc.
05-13-2005 05:07 PM
05-16-2005 07:52 PM
05-17-2005 08:50 AM
05-17-2005 03:45 PM
I'm not sure what you're asking. The front panel control load/time is a switch right in the middle of the front panel. All controls have a single output. They can have multiple values. A Boolean can only have a true/false value. Numerics can have any value between the specified range and data type. If you want to change the appearance of the front panel control so that it has three options, you'll have to replace it. One option might be with a toggle swithc that has 3 positions. Some examples of this have been posted recently here, here, and here. This type of control is really a numeric so you'd have to change some other things in the program
Thank you. I am now trying to change the 2 way switch into a 4 way switch. The example are for a three way switch. Is possible to have a four way switch in LabVIEW?
05-17-2005 04:35 PM
06-02-2005 11:35 AM
06-02-2005 11:36 AM
