10-05-2011 04:54 PM
i have problem with hp 6632B i cant communicate with driver hp66xxbc
i use lv 8.5.1 visa 4.6 measurement & automation explorer 4.6
in MAX i can communicate and control the hp6632B even using lv visa or I/o asistant I can communicate butt but also attend to use the driver saw me not detected hp66xxbc gpib address and i see
error 1073807343 Insufficient location information or the device or resource is not present in the system
thank you very much for your attention
Solved! Go to Solution.
10-05-2011 11:07 PM
10-07-2011 02:50 PM
thanks problem solved
02-05-2013 07:25 PM
Hi guys,
I have same problem here.
In my own case I was able to connect to an agilent N9320B using a usb-to-mini-usb cable from my desktop. However after i have taken readings for say 30 seconds then the error comes up on the Labview.
Pls what can I do. I need urgent assistance as it is strange that after some few readings the error probs up.
I can be reached on +12048073466
Thank you
02-05-2013 08:01 PM
