Tony,
Your NI Spy file is pretty interesting. I'm assuming the problem you are experiencing is shown on lines 2674-2704. What is interesting about this is that ibdev is returning EDVR. The NI-488.2 help file says that this error is returned when:
The board index passed to ibdev cannot be accessed. This error occurs when you try to access a board or device that is not installed or configured properly. Or, EDVR is also returned if there is an internal driver error.
I find this interesting because you can see from the NI Spy file that you were making calls to GPIB0 successfully before this error returned. That may mean that you are experiencing an internal driver error. What version of NI-488.2 do you have installed? I would recommend installing the latest version of the driver which can be downloaded
here. Or reinstalling your driver if you already have the latest version. Let me know if that fixes the problem, and we can troubleshoot it further if it does not.
Shawn B.
