i am having trouble with my labview programs.They used to work fine untill now...
The programs are event driven, you can select a function on the front panel of the main vi which will open a subvi where additional tasks can be done.
Problem is that the subvi's pop-up but you can not
control them, so they kinda run in the background.
You can only click in the front panel of the main vi
but this doesn't do much since there is the subvi whish is being executed (actually waiting to be executed). I had a look a the event driven examples supplied with Labview and they worked fine, i checked all the settings of the sub vi's used and compared them with the subvi's I wrote and there was no difference..
Also I don't use any call by reference
or whatever as this is clearly not neccesary, check examples.
Anyone???
Tx a lot
Bye for now
