no visa resource found - cRIO
For now, I am more worried about the IO boards. Do you know why the IO boards are missing in MAX?
Thanks.
Message 11 of 13
(2,327 Views)
Hi JianZ,
If you are using a Real-Time operating system on the controller, then the modules will usually not be shown in MAX (CAN ports will generally show after the drivers have been loaded). Can you open a project and find the device and the modules? I am guessing that the error you are seeing may be related to the COM or USB ports as those are not shown. Typically in these scenarios I recommend the following troubleshooting steps:
  1. Power down the device
  2. Re-seat all modules (disconnect any external interfaces for troubleshooting)
  3. Reset MAX configuration (Tools»Reset Configuration Data)
  4. Turn the device on and reformat and reinstall the drivers/software (perhaps selecting all the install options for troubleshooting to ensure that you are not missing any drivers)
David C
Message 12 of 13
(2,307 Views)
Hi David,
Thank you very much!
It did slove the problem.
Jian
Message 13 of 13
(2,293 Views)
