NI Home
Cart Cart | Help
You are here:
Reply
Member
MKumar25
measure resistance at resonance frequency of a resonator
I want to mesure resisrtance at the resonance frequency of a resonator( 1 KHz-100 MHz) with a piezo driving the resonator to resonate and a voltage (DC/AC) applied at the source of the reonators while measuring the resitance of the resonators thorough the drain of the resonator.
Proven Zealot
johnsold
Re: measure resistance at resonance frequency of a resonator
You did not clearly ask a question.  What part of this measurement is the problem?
I would probably consider an I/Q (in-phase and quadrature) measurement.  Using complex arithmetic you should be able to separate the real part (resistive) from the imaginary part (reactive) to get what you want.
Lynn
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
