06-12-2012 04:50 PM
Having trouble sending files to the lecroy 104mxi-a. There is a transfer file.vi that takes a file from the scope and saves it to the PC. I am looking to reverse that and send a file from the PC to scope HDD. Lecroy has a manual that mentions the command TRFL that should do it but I think my syntax is incorrect.
TRFL DISK,HDD,FILE,'<file path>' string is going to the LCWAVE Write vi which ouputs an error.
Heres the link to the Lecroy manual:
06-12-2012 07:23 PM
Try the attached vi.
You will have to replace the LCWAVE write.vi with the vi from your driver if it does not find it already. (depends on which driver you are using, .llb or .lvproj).
If you have any challenges, feel free to contact me at 1-800-5LeCroy, extension 6088 (8am to 5pm Pacific Time) and I am happy to help!
Cheers,
Leonard Brown
LeCroy Applications Engineer
06-13-2012 10:10 AM
I knew there was something wrong with my syntax. Thanks for clearing that up. I just tweeked your code so that I separated the source and destination paths into two controls so the files can be in different locations.
06-13-2012 12:51 PM
I am glad you got it working. I wonder what I overlooked when I tried to separate the paths. (I was not successful in doing this so I combined them and added the comment to the front panel).
If you don't mind, I would like to see the modified command that worked with two separate paths.
Thank You,
Leonard
06-13-2012 03:28 PM
It was an easy fix just cut the wire from the path to string vi and connect a new path control.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
