Hi there,
I am currently writting a LV program to get the measurement results from the Hp 16500b, the command to get the data is :SYSTEM:DATA?.
The way I do it in LV is I use the GPIB write.vi followed by the GPIB read.vi but the results I get are not always correct. Let me explain:
the data comming out of the GPIB read.vi is binary not like 000100111 but like yy .
So in order to understand the data I need to convert it to hex. or binary (0 and 1's). Therefore I take the read out string and put it into the string to byte array and then I use tha format into string function (% b, or %x)in a shift register.
But the results I get are most of the time wrong compared to Ni-MAX. If I enter the command :SYSTEM:DATA? in the c
ommunicate with instrument window in NI-MAX I get other results correct results that is!!!
Now what is the difference between a Query in Ni-Max and the GPIB write - read.vi's in LV??
Ni-max shows for instance :
1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00 1f 00
whereas labview gives me:
1F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F01F0
also is there an easy way to split the string in LV to get the hex values sorted 2 by 2 like in Ni-Max?
