05-05-2014 10:06 AM
I use GPIB USB HS controller. When I connect it to my labtop an run MAX I can see the keithley connected to the controller, but when I connect the same controller with the same instrument on the desltop, which have the same labviwe, I can not see keithley. Capture of both cases are attached.
Another question, when I use labviwe code what I should write in the GPIB adress string?? Is it only the primary adersss 22 or the ID, which is zer in my case, should be included also.
Solved! Go to Solution.
05-05-2014 10:52 AM
05-06-2014 06:25 AM
On the desktop, where i have the problem, I have 3.1.2 NI 488.2 an NI VISA 5.4. on the labtop I have NI 488.2 version 2.81 and NI visa 5.1. .Where should I right click
05-06-2014 07:40 AM
05-07-2014 06:29 AM
I attached a photo for the MAX main page and when I right click. also a list of the softwears.
Thanks alot
05-07-2014 06:29 AM
Thanks alot
05-07-2014 07:41 AM
05-07-2014 07:52 AM
I see what you mean. This option is not avialable on the desktop. I can see it on my labtop.
05-07-2014 08:13 AM
05-07-2014 09:53 AM
yep
