Since no one else tried to help, I will volunteer some guesses, but they are only guesses.
Minor issue:
> Call ibwrt(ud%, "SHUTTER?" & Chr(10))
That is perfectly fine Visual Basic code, but for some reason I wonder if you might want to do this:
Call ibwrt(ud%, "SHUTTER?" & Chr(13) & Chr(10))
Major issue, unless I'm being stupid about something:
> Call ibrd(ud%, EtatShutter & Chr(13) & Chr(10))
You have a Visual Basic variable named EtatShutter. Your "&" operators construct a longer string, a temporary value with no name. The unnamed value could be assigned to a variable, or printed, or written. But you aren't doing that. You're trying to read from the device into the unnamed value. Even if the read succeeds, you are doing nothing further with that
unnamed temporary value. Meanwhile, EtatShutter doesn't get its value changed at all.
First try reading into the variable itself:
Call ibrd(ud%, EtatShutter)
After that, check if the last two bytes are Chr(13) and Chr(10), and then extract the rest of the string.
(P.S., if you complain about my English then I will post in Japanese. I could READ most of your French. I hope that my guess can help you.)
