02-10-2014 05:36 PM
So, if i want to have a knob to control V/div a how can i manage it; through vertical range and probe attenuation ;can you give me an example;and something else
also the driver give in configure channel characteristic a vernier(true/false) may be to set this controle i didn't understand this
thanks for the help!I am honestly gratefull.
02-10-2014 06:01 PM
02-11-2014 08:01 AM
the problem when i was measured 30mv and the probe attenuation is 10(vertical range 10) but my program run when i set the probe attenuation to 25
thank you
02-11-2014 08:03 AM
the problemis the program was blocked when i was measured 30mv and the probe attenuation is 10(vertical range 10) and my program run when i set the probe attenuation to 25
thank you
02-11-2014 08:14 AM
