05-29-2014 12:54 AM
I am trying to read data from fresenius vial pilot C syringe pump. Getting following error in read operation:
"Timeout expired before operation completed". I have checked the baud rate, parity etc and also the rs 232 cable. Where can be the problem?
05-29-2014 12:59 AM
05-29-2014 02:12 AM
Manual is attached. I am not able to read through MAX also.
05-29-2014 02:24 AM
05-29-2014 02:27 AM
I am also trying to use attached program. Put nothing coming in read display.
05-29-2014 02:36 AM
I am using following string to write:
[02h]\s3PR;1F4014\s[03h]
06-30-2014 12:30 AM
First of all I need to change to PC mode. For this I am sending through MAX:
02 33 4D4F3B32 C3 03
entire command is in hex format
and I am getting error "Time out expired before operation completed".
RS232 protocol is attached.
regards,
Manu
06-30-2014 12:47 AM
Please help.
regards,
Manu
