Hi TSnow,
The ibdiag() function is no longer supported in versions of NI-488.2 past 1.7. It was never formally documented and was meant only to be used internally. Unfortunately, there is no function in versions past 1.7 to perform a similar function.
If you are looking to use the same program you have used in the past, you may still be able to use the same version of the driver so that the ibdiag function will still be available to you.
John M
