04-07-2014 02:55 AM
Hi, I've a Hp 3311 A function generator and I'd like to control it by GPIB. I'd tested with the example in labview "GPIB.vi" but when i send it a command, pej "APPLIN 1.0E+3, 3.0, -2.5" it doesn't work (It makes only a sound "Bip" ).
Does anyone knows why the function generator doesn't generate the signal?
Note: When i send it the command IND?, the instrument returns the name "Hp 3311A", but when i send another command it doesn't work.
Thanks. Regards, peliasrojo.
04-07-2014 07:21 AM
04-07-2014 01:47 PM
Are you SURE that is a 3311A and you didn't typo a digit?
That guy is so old I had to double check. It has no remote interface. It is possible that one was made available as an option in some years. The interface would not be SCPI compliant
04-09-2014 06:42 AM
Yes, you are rigth. The model is HP 33120A.
I can change the signal (ramp, square, etc) buy I don't be able to change the parametres (frequency, amplitude, etdc).
04-09-2014 07:33 AM
04-13-2014 01:40 PM
Hi. I don't use the drivers, I'm using the example GPIB-VISA. I'm be able to change the type of function (sin, square, etc) but when i try change the frequency or the others parameters it doesn't work.
I've attached the program (v2011). The program only tries to apply a square signal with visa commands.
The manual shows an example of a sine function: "APPL:SIN 5.0E+3, 3.0, -2.5" that generates a sine function of 5kHz, 3Vpp and an offset of -2.5V.
Thanks, regards Peliasrojo
04-13-2014 02:48 PM
