NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
l@bviewer
how to toogle between channels
I need feed the same data in a loop into DO lines. These lines should change between two sets of lines from iteration to itetation (you may think there is only two lines to toogle between) i.e. on the first interation the data are fed into first line, then into second, then again into first e.t.c.
What is the most concise way to accoplish this? I'm using DAQmx.
Active Participant
Justin_P
Re: how to toogle between channels
duplicate of here
Justin Parker
Product Support Engineer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
