09-08-2005 07:29 AM
09-08-2005 08:06 AM
09-08-2005 09:39 AM
Thanks for the quick reply. The (simple) code i'm using is given below - 210scope is the Locical name for the ivi driver I' musing, tktds2x0. I'm using the tecronix 210 scope, althoug I do have other scopes with IVI drivers I haven't tried yet.
where m_pScope is a CNiIviScope pointer:
m_pScope = new CNiIviScope("210scope", false, false);
m_pScope->Measurement.ReadWaveform("CHANNEL1", 10000, waveform, xFirst, xInc);
double range = m_pScope->Channel.GetRange("CHANNEL1");
double offset = m_pScope->Channel.GetOffset("CHANNEL1");
delete m_pScope;
It takes a few seconds - perhaps 5 secs - to establish communication with the scope, and another 1 or 2 seconds to grab the data. One or two seconds is acceptable.
You seem to be suggesting that because IVI does offer state caching, local control of the scope will always be locked, and there is no 'better' or faster way to release control to the user, other than deleting the scope object (and therefore the session). Is that correct?
I guess I can maximise connection time by unchecking all the initialisation options which may slow it down, such as 'range check' etc. Anything else I can do?
09-08-2005 01:22 PM
// "LOCK NONE" is the tek200 series command to unlock the front panel during remote operation.
tkds2x0_WriteInstrData(specificDriverSession, ":LOCK NONE");
//Then, when you want to actually read the data:
If you do this, you shouldn't have to close and reopen the session repeatedly.
BUT - it's only going to work with the tek scope. You will need to link in the tktds2x0.lib file and include the tkds2x0.h header in your project. If you need the application to work with other scopes as well, there are other tricks we can employ - like pulling the specific driver prefix from the class driver, doing a LoadLibrary and GetProcAddress to get the WriteInstrData function pointer, and then use the config store to keep the command to send (if needed) to unlock the front panel associated with the Driver Session for each kind of scope you need to support.
09-12-2005 04:43 AM
OK, thanks. I would like the same functionality for ANY ivi scope. Could you please clarify a couple of points:
1 - will ALL IVI scope drivers have an exported WriteInstrData function?
2 - for the general case, are you basically suggesting to have a 'lookup table' with specificdriver name, or prefix and the command to unlock the scope? I could have this data in an external file.
3 - you mentioned using the 'config store to keep the command to send'. What is this config store?
Many thanks for your help
09-12-2005 09:48 AM
1) IVI-C drivers written with National Instruments driver development tools will include WriteInstrData and ReadInstrData functions. Unfortunately, those functions are not required in order to comply with the IVI specifications, so drivers written with other tools or from other vendors might not have them.
2) You're exactly right - you'd need a way to look up the command to send for each specific driver. That lookup would probably need to be done based on the specific driver's prefix.
3) The config store is the file that maintains all of your IVI Configuration information. When you define logical names, driver sessions, etc. in MAX, all of that information is stored in the IVI Config Store. It's an XML file located in c:\program files\ivi\data\iviconfigurationstore.xml. The config store includes a limited extensibility mechanism by which you could associate information for a specific driver with that driver session or software module, and then programmatically retrieve it through the IVI Configuration Server API. However, this may be too heavyweight a solution for your needs, if this is the only setting you need to hack around like this. Maybe it makes more sense to keep the information in a separate, more manageable file.
Most devices that can programattically lock out the front panel have some sort of override button that lets you re-establish local control, so you might not even need to handle it programatiically for some other devices. Do you have a fixed set of devices you want to support, or are you writing an application you need to work with whatever scope the user happens to have? Another idea, if you're willing to try it, is to remove the "Lock All" command from the Tek driver's initialization routine and rebuild the driver. The downside of this approach is that you're going to have to maintain your own version of the instrument driver.
09-12-2005 10:25 AM
Excellent. Thankyou very much for the info. I'll go down the separate file route to maintain the unlock command and driver prefix. As a fall back (for 'unknown' scopes if the device prefix is not in the file, I'll give the user the 'fast' option of leaving the panel locked, or 'slow' option to unlock each time by deleting the scope object after each readwaveform.
We do have a specific set of scopes, but we want the software to be relatively 'future proof' so any new scope will work (to some extent) 'out of the box'. There may also be a limited distribution of the app.
