03-30-2010 03:15 PM
Hi Everybody,
I am new to Labview. I am trying to connect ESP 301 motion controller from Newport to the labview and control it. But I couldn't find the drivers for it online. How can I connct it and using.
I am planning to use it with USB connection.
Could some one please help me in this regard.
03-31-2010 11:54 AM
It seems from the newport website for the ESP 301 that the device has an extensive library of LabVIEW drivers. These drivers can be found on their FTP site at the following location.
ftp://download.newport.com/MotionControl/Current/MotionControllers/ESP301/Software/
These drivers are developed by NewPort and should provide the necessary interface to communicate with the device. The commands that can be sent using these drivers should be available in the user manual for the device.
12-14-2013 03:35 PM
Hi, the link can not be opened. I found that the labview driver presented in website can not run , always has errors
12-14-2013 05:47 PM
09-27-2014 02:31 PM - edited 09-27-2014 02:33 PM
I want to order the two axes simultaneously
Ie d .: axis X moves to a stop value, and then 50 microns, and the other axis Y moves to a value of 40 microns, for example,
Not like the program published by the manufacturer which is in link (ftp://download.newport.com/MotionControl/Current/MotionControllers/ESP301/Software/) Ie d (C: \ Program Files \ National Instruments \ LabVIEW 2011 \ user.lib \ Newport ESP301 \ Example :: Motion Virtual Front Panel_libESP301) to program it asks for the choice of the axis (line 1 or line 2).
I want to post an assisted how to make a command to move the 2 Motors directly using front are passed by the choice of axes.
thank you
jilali hallabi
09-29-2014 09:53 AM
Hello Jilali,
This is an inactive thread. Could you please create a new thread, referencing this one?
Also, could you please explain, in the new thread, your desired behavior in more detail?
09-30-2014 11:33 AM
Hello Thomas
there are existing facilities:
· Two turntables XY driven by stepper motors 10 microns
· Central ESP301 command to the decks
· Central control and data acquisition: Unit PXI
I want to do the next step
· Control of stepper motors to perform scans on a large scale wafers two or four inches with a very good resolution of up to 10 .mu.m
· Programming the ESP unit 301 microstepping mode by dividing the initial step to make scans on small areas at a resolution of up to 1 .mu.m;
10-01-2014 12:08 PM
Hello ucd,
This is an inactive thread. Can you please create a new thread, referencing this one? This will increase the visibility of this question.
If you have questions on the ESP301, I would contact Newport to discuss how their equipment handles the wanted behavior.
05-26-2017 03:38 AM
Is there a current link, I'm trying to download the driver and nothing works
05-30-2017 09:32 AM
Here is the link to the product page of your hardware. If the driver is not on their site, I would advise contacting them.
This instrument driver is NOT supported or maintained by National Instruments. This driver is maintained and supported by the instrument manufacturer or a third party.
https://www.newport.com/f/esp301-3-axis-dc-and-stepper-motion-controller
