07-01-2015 05:00 AM
through NI Max, I am able to see my GPIB ethernet controller, but I am not able to see the instrument connected. I have the HP-IB address for the network analyzer as
for 8751: 17
controller: 21
these were taken from the local properties of the instrument. In NI Max, under the general settings of the GPIB interface properties, what should I mention in the primary address and secondary address column to be able to communicate with my network analyzer. Moreover, should I keep the system controller option ticked or should I unmark it ?. Awaiting response asap.
Thanks in advance !!!
07-01-2015 05:42 AM
In MAX, there is a Scan For Instruments under the GPIB. Your instrument should just be detected from that.
07-01-2015 06:59 AM
I scanned for instruments under GPIB control, but still it shows no instruments added
07-01-2015 07:14 AM
Wait a minute. Why is your controller at address 21? You GPIB card should be at address 0 and made the master.
07-01-2015 08:48 AM
21 is the HPIB address of the controller in the network analyzer. The suggestion is: I change this controller HPIB address to 0 and try communicating. But this is the default address given in the manual of the network analyzer.
07-01-2015 09:10 AM
Now you are just being confusing. Exactly what hardware do you have? How exactly is everything connected?
07-01-2015 09:38 AM
Hey,
sorry for the miscommunication. Now I can see my instrument after changing manually the controller HPIB address in the network analyzer from its default value of 21 to 0 as suggested. Thanks for your valuable guidance.
