hi Salvador,
Update: I try jus putting a for loop and wait(ms)with VSET-200V;VSET?VSET-2000V;VSET?.. it ended up giving me the same plot line at the same position after the wait time, for many iterations.
I am wondering for the pseudo-code u mention above, do we have to manually set voltage of power supply every time the loop iteration finish, and go to the next iteration? (considering the time delay is quite short) Or is there a way which i can send a string or all commands to the power supply to increase from 200 to 400 (step1), 400 to 600 (step2), and so on, to automatically change the voltage at each step throughout the N iterations? or do we only set the min of 200V and max of 2000V..
Furthermore, can
i say that the first loop iteration is i=1 to 10, next i=11 to 20, the 3rd i=21 to 30, and so on, until the value of N? is the file attached what you mean for the series of loop iteration?
Thanks a lot.
From,Student
