You can use VISA to control an instrument with an ethernet interface. Open a connection using a resource name of TCPIP::host address and then you should be able to send your SCPI commands with VISA Write just like you would with a GPIB connection. You should also verify that it's on the LAN from MAX. Right click on Devices and Interfaces, select Create New and then select TCP/IP Resource and then follow the directions.
