05-24-2016 02:23 AM
I am trying to design an xy-stage. I encountered the error 10109 which says that 'Control HW Communications Disabled'. I have attached my code below. There are 2 serial numbers because I have 2 stages. I would really appreciate any help on this matter. Thank you!
05-31-2016 01:14 AM
Hi johnkwok,
This is a third party driver and most likely this error is caused from the invoke nodes in your program. Since we don't have documentation or resources to help explain this error, it would be helpful to contact Thorlabs to see if they have any documentation on it.
You can also refer to this post which is having the same error: http://forums.ni.com/t5/LabVIEW/error-10109/m-p/2399052#M742937
Here is the User Guide to LabVIEW & APT document. It should be helpful if you need to modify your LabVIEW program that communicates with the Thorlabs device: http://www.thorlabs.com/images/TabImages/GuideToLabVIEWandAPT.pdf
Rufan Mo
Applications Engineer
