I did some tests and alas, nothing helped so far. I verified that the network settings were correct, with the right IP address and subnet mask.
I started ping -t 192.168.0.111 and opened a connection to the box. After almost exactly 60 seconds (I timed it this time) the green LED on the box went out while the ping kept reporting answer times of <1ms.
So I went and downloaded NI-Serial 1.7 and installed it. No change!
Then I looked at the network card which is as far as I can say the only difference to the other computers. While the other computers which work properly have a Broadcom 440x network adapter on board, this particular computer has an Intel Pro 100/VE adapter on board. So I downloaded the newest Intel drivers and installed them on the computer and the according network properties panel has now an abundance of different properties for this adapter with neat explanation of all of them. I tried it again and also did several changes to the network adapter properties such as buffer coalescence, buffer send delay, etc and checked everytime in between and again nothing changed.
The most simple test I did was just looking at the port in MAX and select Open VISA session and then wait for 60 seconds to see the green LED go out. The orange Rx LED does blink in between a few times as if the box would have some network traffic from somewhere (I would assume the host PC) but the problem simply persists no matter what I do.
I'm at the end with my knowledge. It does appear that the driver does for some reason not send the heartbeat message on this machine or in a way which is very different to the other traffic it does to communicate with the box.
I'm short before rewriting the LabVIEW app to open each serial port each time it is needed and then close it again, but this seems like such a stupid workaround to me and one of the devices I use has an intermediate DLL from the manufacturer and here that trick won't work.
Chris can you maybe try to come up with a better idea what might be wrong?
Rolf
