06-28-2015 03:24 AM
07-03-2015 10:04 AM
hello. it is really hard to understand what you want to do.
from what i understand so far, you have existing code that you want to integrate into labview in order to provide the users of your hardware with a labview code to control the hardware.
if so, why does the call library function node not work for you? is it because you want to pass certain parameters? this is possible with the function node. maybe this tutorial helps: Configuring the Call Library Function Node to call a Simple DLL, https://decibel.ni.com/content/docs/DOC-9069
if this is not what you want to achieve, please try to be really specific. what should the labview code do in the end?
07-04-2015 12:07 PM
Thanks all for the help,
The solution is: I found now the way combining both, the driver approach and within that using dll function calls. The driver will be just at is, ant it is not actually an "driver" in the classic way, since the connection to the hardware is done in the library functions. But using the driver interface gives an easier possibility to customize existing Labview code to use with the new hardware.
