For a PI motion controller I need according to the manual the rs232 cts/rts handshake. As I have seen this can be selected from the 'open serial port.vi'. However, the instrument driver provided by the manufacturer doesn't switch the handshaking on in the open serial port.vi .
If i switch the handshaking off i can see a signal at pin3 of my serial port. I also see something when I switch on either RTS or CTS. When I switch on both I don't see anything (that's what I might expect). But -and here is my question- I never see anything on the RTS pin of my serial port, nomather which handshake settings in the 'serial port open.vi' .Could anybody give me suggestions about the RTS/CTS handshaking for LAbview ? I'm not using the VISA package since the
instrument driver from the manufacturer didn't use it. I'm working with Labview 6.1 and SUSE linux OS.
Thank you very much
