Hi DonLabVIEW,
First let me recommend that you use the instrument drivers available at www.ni.com/idnet, our Instrument Driver Network. These drivers provide you with VIs that take care a lot of the lower-level details and will greatly aid you in your programming. You can select Search Drivers and search for your different instruments. We have drivers available for most of the devices you mentioned.
Now, I am not quite sure what exactly you are wanting to do with this configuration file. Are you wanting to have some settings saved on your computer that you can read into the program to know how to set your instruments for the test? If so, you can use the File I/O functions, read in the file, and then parse out the data from the file and use it in the program to determine what settings you want. If you just have a sequence of tests you need to make, there are several ways that you could set up the program to do it on its own without having to read from a file. I hope your programming is going well, and please let us know if there is anything else specific that we can help you out with!
john
