01-13-2012 02:23 PM
Dear all,
I met some difficutied on how to control my instrument (Photometrics Controller CC200) using GPIB/USB interface (NI-GPIB-USB-HS). I can control the instrument to do many things. For examples, I can control the camera to take a picture, and can show the picture on the monitor of controller CC200, also I can read the parameters of the picture. But if I use the command which was used to write the current image cache to hard disk in my computer, it shows the error EABO. I have tried all the termination method, but it doesn't work.
How can I solve this problem? Thank you.
01-13-2012 02:49 PM
01-16-2012 01:12 PM
Hello phywff,
Here is a useful Knowledge base regarding this error you are getting.
GPIB Error Codes and Common Solutions (Part 1)
01-18-2012 09:42 AM - edited 01-18-2012 09:49 AM
Hi Miriam and Netherlands,
Thanks for your helping.
I have try to solve the problem according to Miriam's attachment, but it still doesn't work.
I use the Labview7.1. If it is too old?
01-18-2012 09:48 AM
Hi Miriam and Albert,
01-18-2012 11:59 AM
Since you have not shown your code, it is impossible to say what is incorrect. The version of LabVIEW should be irrelevant.
01-18-2012 12:11 PM
01-18-2012 04:30 PM
Thanks all,
I have not finished my vis. I just use Measurement & Automation to communicate with the instrument. And I have tried to prolong the timeout and I have tried all the termination method.
I need to create the vis first even if I can't use Measurement & Automation to communicate with the instrument?
Another question: I need to save the *.img file to my computer from , so which function shall i use, ibrdf or ibrd.
01-18-2012 05:08 PM
I use either VISA Read or VISA Read to File. I have not used the low level GPIB functions for many years and I don't remember how to set the timeout value. With VISA, it's trivial to use a VISA Property node to set it. It's also easy with the VISA Interactive Control in MAX.
01-23-2012 09:14 AM
Attachment is my VIs.Please help me to check it. Thanks.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
