03-07-2011 05:19 AM
Use portmon to capture the serial data stream that is being transmitted and post that info.
03-07-2011 03:59 PM
Hello nadeemalikpda
How have you progressed on this issue? Are there any new developments? Let me know where you are currently with your issue so that I can address it appropriately.
Thank you very much!
Greg S.
03-05-2014 11:46 PM
Can send me VIs for coomunication with Mitsubishi FX PLC PLZ
suprasad.wagh@gmail.com
03-06-2014 12:44 AM
06-04-2014 01:19 AM
i am also working on delta plc i have the dsc module i have use the modbus and opc server to communicate plc with labview but there is no progress
06-04-2014 01:28 AM
does opc server have driver for delta plc
@nadeemalikpda wrote:
hi
i m using Modbus to communicate plc with labview . but it is not working.......?
can any one give me the example program so that i can understand how to communicate ?
hi
hi
hi
hi
hi
06-04-2014 06:33 PM
Hello Faizi,
What type of issues are you running into trying to communicate with your PLC? If you could give us more details, we might be able to help you.
Ryan
06-05-2014 02:59 AM
Hi Ryan
problem is that plc is not responding,i don't know if i have to program my plc, how to identify the address of input pins of plc to labview and how to make a ladder digram which will identify labview data.IF a sensor is attatched to plc x0 how would plc will send it's data to labview and how would labview will acknowledge that data has come from x0
06-06-2014 01:18 PM
I can't speak much for programming the PLC itself, but I can recommend the best ways to communicate with a PLC from LabVIEW. The general process requires the use of an OPC Server which you can use to communicate with your PLC via standard OPC communication. I recommend taking a took at the article linked below if you want to know more in detail though.
Connect LabVIEW to Any PLC Using OPC:
http://www.ni.com/white-paper/7450/en/
06-06-2014 02:55 PM
Actually, this is the article that I meant to provide you.
Connect LabVIEW to Any PLC With Modbus:
http://www.ni.com/white-paper/13911/en/
