05-07-2014 10:01 AM
Hi There,
I'm trying to develop an application to control and communicate with 5 Eurotherm 2704 controllers on the same bus, the program works with RS232 but I cannot get it to connect via RS485, I have all the correct modules installed in the Eurotherm unit and I have tried every concievable wiring configuration, loopback tests via MAX show that the port is working
eventually I hope to be able to connect to a cRIO-9068 unit, however I'm unable to establish comms, I'm thinking it may be a voltage level issue, has anyone else successfully connected a 2704 controller to a cRIO unit of any type via RS485?
is there any specific issue that anyone is aware of?
many thanks
05-08-2014 10:49 AM
The KnowledgeBase article whcih describes how to connect these up is here: http://digital.ni.com/public.nsf/allkb/D31BAE31637E9D2D8625669F00671AAD?OpenDocument
Have you connected up the pins as described therein, and have you connected the device up in "2 wire TX Rdy Auto" mode?
Best wishes,
05-09-2014 10:00 AM
I am informed by Eurotherm tech support that the 2704 unit will only operate in 5-wire connectivity, the article you linked says to connect in 3-wire topology by bridging pins, I am informed this will not function...
can you please inform me how to connect in "2 wire TX Rdy Auto" mode?
I appreciate your response
Simon
05-12-2014 05:17 AM
I'm very sorry, but that is the only information I can find on the NI side about the correct topology to connect up the Eurotherm board, and I believe it's our recommended setup with our serial boards - it may be worth checking with their tech support for further suggestions if you find that this doesn't work.
In terms of changing the port settings - instructions can be found here: http://digital.ni.com/public.nsf/allkb/1D516C10D7EDFAC6862571110073B8F4
I hope this helps!
